DAX Tx stream drops when changing bands
butch alline
butch alline Member
edited November 2016 in DAX
SSDR 1.6.21, Win 10, problem has been resolved but posted for comment.  Here is what happened:
I had set up a global profile for fldigi on 40 and 20 meters.  I could switch bands between 40, 30, and 20 meters at will with no DAX problems.  However, if I switched to any other band the DAX tx stream turned off.  This was consistent and repeatable.
I then set up a 15 meter fldigi global profile identical to the 40 and 20 meter profiles and everything started working fine - I could switch bands and still have DAX tx streaming!
Any ideas?  SSDR or Win10 weirdness?
