Looking for ideas to solve CAT problem
YV5WZ
YV5WZ Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
Hello to all!
Today while I was listening to radio looking for good Dx  power went out....energy fail was in a big sector during 1 hour...
After a while when energy power was solved I got back to my radio.. and decided to do some digital work.....WSJT-X didn't recognize CAT com 4 ....I opened CAT Box.....and nothing in Process...I opened slice B...and Another WSJT-X windows ( I have  2 WSJT-X).....and CAT com 6 work fine....
I remove  CAT com 4  and installed Slice A on CAT port 5......WSJT-X listen and decode....but doesn't  PTT the Rig and don't recognize Frequency........if I change to port 6 on slice B...it works
I decide to Uninstall......and did a fresh  intalling......Com 4 never showed again.....and Slice A is on CAT com 5.....but problem persist.......Any Idea?
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited March 2016
    Sounds like the same problem I hear every day. You probably didn't completely uninstall SmartSDR.
    Jim, K6QE
  • YV5WZ
    YV5WZ Member ✭✭
    Wow!.....I did .....But I will do again
  • YV5WZ
    YV5WZ Member ✭✭
    Ok I now Cat ports..disappear  when I turned off system....and when I create other is going up to another port highter
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    Is it possible that windows moved some hardware device into the COM4 slot... You may also need to look  and remove for hidden devices in the windows device manager..
    AL, K0VM
    edited March 2017
    George, the power outage has corrupted the CAT configuration file.  I see you have opened a HelpDesk ticket (which was the correct thing to do).  I should be able to manually recover it, so just get me the info requested and we'll get you back in business.
