SmartSDR+not+connecting
The RFMD ARC JUST unboxed our new 6700 today.  Followed the QSG, upgraded to the latest SSDR(v1.6.21) 6700 firmware was good to go.  SSDR 'sees' the 6700 as it displays the Model type correctly, and shows a 192.168.2.X IP address.  The SSDR computer and 6700 are connected to the same Ethernet hub.  The 6700 HW Version is: v1.6.21.77.
Alas, when we 'click' on the green 'Connect', SSDR just freezes.  Did we miss something?
Thanks,
Duane
  • Stu Phillips - K6TU
    Stu Phillips - K6TU Member ✭✭
    edited May 2020
    You are probably being bitten by the IP firewall in Windows and/or in your AntiVirus software,
    Step 1: Turn BOTH OFF
    If you can then connect, you will need to find the appropriate steps to allows SmartSDR, SmartCAT and SmartDAX to be allowed network access.
    Stu K6TU
  • Duane Brantley
    Apparently you need to reboot the radio after upgrading SSDR.  All is well now.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited December 2016
    Yep...when in doubt...reboot!  that's my motto.
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited October 2019
    There are two (2) message with the same questions from Duane Brantley...
    In this forum...
    That Stu K6TU answered,
