Problem N1MM + DAX + VOX
Javi LU5FF
I'm in the ARRL SSB contest and I encounter a problem when activating the DAX of SSDR to send me N1MM called overrides the MIC my headset ..I do not use PTT switch, I think I would have to allow to do both, send the audio memories and use VOX at a time.
thanks for any help
73s
Javi LU5FF
thanks for any help
73s
Javi LU5FF
I agree with Javi.
It is indeed impossible to use VOX to activate the MIC if you are using DAX with N1MM to send phone calls.
I recently had the same question but it was due to a different need on my end.
At the end of the day I think the easier solution is to have both the MIC audio IN and DAX TX enabled.
Also discussed here https://community.flexradio.com/flexradio/topics/mic-ptt-not-working-when-dax-enabled1
- 402 Community Topics
- 693 The Flea Market
