One 6700 Two Maestros
Maestro gives you access to 2 Slices. SO2R is pretty much doable with one 6700.
How about Two Maestros connected to the same 6700, each one assigned to a different SCU?
With 8 Slice receivers you could potentially have 4 Maestros connected to a 6700, but I think the limiting factor is the SCUs.
So is it doable? Assign a Maestro per SCU in a 6700?
It could also be Maestro+PC with 1x6700.
Sal, I believe that violates the 2 clientGUI rule.
