SDR-BRIDGE 1.5.0 mutes audio
W5UN_Dave
The new v1.5.0 SDR-Bridge no longer lets me disable the mute when I add a slice. How do I now disable the mute feature?
On the Radio tab make sure "Mute all but active" is not checked. This is the only option that affects audio muting. If you still have a problem, please post more details or open a support ticket on http://www/qrv.com
Thanks,
73 Ed W2RF
Ed, I find no "Mute all but active" option on the radio tab of 1.5.0.123. It was there on the earlier version, but now I only see the window showing frequencies. Am I missing something? The link you show does not work, so I posted here instead.
Hi Dave,
The Link should probably be:
http://www.qrv.com/
Here is a snap of what the radio tab should look like...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW.................... V 1.6.21.77
SSDR / DAX / CAT...... V 1.6.21.159
Win10
Dave,
Al's snip is what the Radio tab is supposed to look like. Please post a snip of yours so I can try to figure out what's going on. But first I recommend uninstalling and reinstalling SDR-Bridge.0 -
Ed here is what mine looks like
It looks like you have a legacy theme selected. What version of Windows are you running?
running Windows 7 Ultimate 64 bit (legal)
I've totally deleted, rebooted, and reinstalled. Still no joy. The previous version showed as NN4ZZ's snip.
Do the other tabs display properly? Except for adding the Knobs tab, there were no other changes in the UI. So I believe there is a problem with theme selection on your machine. Go to Theme Settings and check. I suggest trying the default Window 7 theme. If that doesn't work, try reinstalling v1.1.3 and see if it displays properly.0
Ed, themes has everything to do with it. I had to switch to the basic theme (showing the awful windows logo) and there it was. That is the only theme that will show the three check windows. I unchecked the MUTE, and switched back to my usual theme. Thanks for the tip.
Dave, If it's okay i'll add your snapshot and solution to the next version of my quickstart guide. Regards, Al / NN4ZZ0
I'm booting to Win7 now for further tests....
In Win7 x64 Ultimate I did not experience this problem. I suspect that something is corrupt in your themes, but don't know what. I would need to be able to reproduce the problem to get a better understanding. Perhaps other users will have a similar experience.
73 Ed W2RF
yes Al, all is OK.
Thanks Dave.....will wait to see what else Ed or others also find. Regards, Al / NN4ZZ0
My short report with Win7 here:
i guess make sence0 -
Sergey,
Your display is similar to Dave's. Did you try changing the theme to Windows 7 default? What theme are you using?
Thanks,
73 Ed W2RF
Hi Ed, no themes in use at all - Windows Classic with switched off all effects. All settings for maximum performance .
however........strange behavior, have tested with Win10 an Win10Pro Preview - everything fine:
hmmmmm ?0
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 176 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 219 FLEX-8000 Signature Series
- 924 Maestro
- 53 FlexControl
- 862 FLEX Series (Legacy) Radios
- 897 Genius Products
- 456 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 445 Remote Operation (SmartLink)
- 141 Contesting
- 759 Peripherals & Station Integration
- 139 Amateur Radio Interests
- 979 Third-Party Software
