SmartSDR 1.6.21
dlwarnberg
Once again, no issues with the install and all is working well... Got it installed last night and initial testing this morning showing no issues.
Thanks again FLEX
Thanks again FLEX
My install went great too. No issues. Then . . . I uninstalled 1.6.17 and uninstalled dax drivers by mistake. Had to uninstall all and reinstall and all is OK again0
Happy to report this release went much smoother then 1.6.17 had no issue with this update.
Ian
Ditto, here too.0
No problems at all here. Being as this was just a maintenance release, I just uninstalled 6.17, keeping the drivers and installed 6.21. Back up and running in a matter of minutes.0
I upgraded my 6300 this afternoon. No problems here. Uninstalled 6.17, installed 6.21. I did keep the drivers like W0FG. It is running with no problems.
The related firmware upgrade seems to have not gone well for me. : (
After the firmware upgrade, the radio "freezes" a few seconds after boot-up but before Smart-SDR can run with it. I have a support ticket entered.
Update: The problem was resolved by doing a "white indicator" reset as described in other threads (and the hardware reference). whew! <sound of relief > : )
After that reset, I found the firmware had been successfully upgraded.0 -
No problems with upgrade, Win 10 / 1.6.17 ==>> 1.6.21
This time I did a complete uninstall of all previous versions. I followed the instructions provided by Flex. I'm running Windows 10 and have had no problems at all. Install went without a hitch and the entire process only took about 15 minutes.
Install here without a hitch also. New to the 6300...1 week today. Running Windows 10 and performed the update without uninstalling 1.6.17. Interesting to watch the radio and update program go through the paces. Everything is working just fine here.
- 684 The Flea Market
