PowerSDR and SmartSDR running together
Peter Bentley
Peter Bentley Member ✭✭
edited November 2017 in FLEX-6000 Signature Series
I would like to run PowerSDR 2.7.2 and WSPR-2 TX and RX, band hopping, on my Flex 5000A and at the same time run SmartSDR 1.6.17 on my Flex 6700 with say SSB on one slice and CW Skimmer on a second slice.
Is this possible with SmartCAT and DAX loaded.  ??
Guidance and comment on the tricky CAT and Port setup for the Flex 5000A would be appreciated.
G4BIM
  • Al K0VM
    Al K0VM Member ✭✭✭
    The CAT ports created by SSDR CAT1.6.17  can not be used to interconnect 3rd party software ( i.e. PowerSDR <> WSJT) .  DAX virtual audio could be used with 3rd party programs with care but independent Virtual Audio Cables (VAC) would be a cleaner solution.
    AL, K0VM
    edited March 2017
    Yes, these applications and their add-on DAX and CAT software packages should operate independently from one another.
  • Peter Bentley
    edited February 2016
    Thanks Al, it looks like it could end up a can of worms, re introducing VAC etc.
    Best wishes
    Peter G4BIM
