SmartSDR v3.9.19 and the SmartSDR v3.9.19 Release Notes
Using my PC's speakers simultaneously on my Flex 6300
After using several different speakers on my 6300 and not liking the extra space they took, I tried hooking the 6300 speaker output to my computer's Line In and selecting "Listen to this device" in the Line In Properties dialog. I've now been running this way for months and love it - even doing split to work the DXpeditions. Windows will mix other sources such as Echolink and if want to focus on that I simply mute or turn down the 6300. My computer speakers are a great set of Sony speakers that came with a Sony computer years ago. The computer is long gone but the speakers sound and work great so I keep using them. Now I only need one set of speakers for radio and computer.
Can you tell if there is a delay between the sound out of the speakers and that of headsets connected directly to the Flex radio? I am curious. I understand you are connecting directly from SPRK out in the Flex to LINE-IN in the PC with no DAX interaction.0
There is no appreciable delay. I connected my headset and listened to both at the same time and heard just the slightest hollow sound. So any delay is negligible in my system.
I also tried using a DAX connection but then you lose the volume control and mute in SmartSDR's main window, so I'm sticking with my wire between the radio and computer.0 -
my computer analog sound is gone. I only find digital in/out with my realteck sound, which is worthless to me.. I reloaded the MB sound driver, but still no analog. I had analog the last time I checked, but it is gone. I wonder if DAX is causing this? Does anyone have any idea why this might be?
Dave, W5UN
Some sound cards will not have analog as an option if you don't have something plug in the jack port. Or at least it shows greyed out.
The way my Realtek sound card works, I can plug anything to any of the jacks and then define with the computer what type of device it is.
The complete disappearance is odd, as even without anything plugged in it appears in the devices window. I wonder if you disabled it....0 -
Thanks ****!
It is an interesting approach. I use the Bose companion with 2 inputs and connect both PC and Flex to the speakers, but this system will allow for a 3rd device to come out of the same speakers.0 -
Dave, depends on what version of Windows you're using and whether the device is Enabled, etc. Shoot me an email via addr on qrz.com and let's take this offline. Probably need a phone call to walk through the possibilities.0
Why would you not just use the Remote option and avoid the additional cables?
Please explain Remote option. There's nothing more simple than a speaker out to a Line In cable between two boxes 2' apart. Occam's razor.0
With the Remote in the upper left of SmartSDR turned on the audio from the radio is send to the PC. There is no need for direct cable from the radio to the the PC. The additional cable could also add to troubleshoot of RF issue when transmitting so the fewer the cables the few entry points.1
**** I'd like to send you an email, but you did not give me your call for lookup on qrz.com
Ha, quite right Dave. It's KF5SA ... typically part of my user-ID on forums but not this one I see.0
OK David, I had thought was only for LAN Remote use as described in Section 16 of the manual, and it says it uses Windows defaults for BOTH speakers and microphone, which wouldn't be correct for the mic. But I tried it and it still seems to use the Flex mic and not the computer mic I have as the default. So I'll have to explore this more. Thanks.
The speaker and mic remote options are flexible. You can set them independently for remote or radio. This makes it so you can have one operating setup in the radio room and another in the living room, patio, etc.
The only disadvantage of using REMOTE, is that it does not let you hear the CW side tone. I use wireless headphones while operating CW so it isn't an issue for me. Other than that, REMOTE works great and there aren't any additional wires.
I see that I must plug something into the MB audio jack before analog is available out of the computer. I will simply run a cable from my Flex 6700 audio out to the computer line in jack (2'cable).
I do not understand this REMOTE business? My REMOTE is grayed out and unresponsive to mouse clicks. If I run remote with my laptop on the LAN, then REMOTE comes into play.
Dave, W5UN
My REMOTE is greyed out on my desktop PC if I do not have a cable plugged in to the speaker jack of the computer.
Mike, W9OJ0 -
Do you have it enabled in the Radio setup as well? What happens when you click the Remote button to enable it?0
Dave - Place you mouse over the Remote button on the SmartSDR console. It will show text on what is your default playback and recording audio device for your PC. You have to have a default Playback (speakers) to hear audio and a default recording (mic) to transmit.,0
That doesn't seem to be important - Disabled here and I'm still using Remote for audio on the computer just fine. The Enable/Disable must apply to some other aspect of Remote.0
**** - Remote On is the hardware remote trigger on the back of the radio and has nothing to do with remote audio. Remote on is a way of remotely powering up the radio with a remote controlled switch.0
Just discovered a major reason for NOT using Remote - FRStacks Hotkeys for manipulating volume do not work with Remote audio. I tried the SVolUp and SVolDown and they didn't work - don't know what they're for yet. Also there is slightly less audio for the same position of the volume slider when using Remote. I use the Hotkeys quite a bit for convenience so that's a Remote-killer for me right now. Perhaps FRStacks will add RVolUp, RVolDown, RVolMute, etc.0
That's right. I confuse that one with audio. It would help to have the hardware Remote On say Remote Power instead since it is to enable the rear connect to turn the radio on and off not just on.
It is designated as such in the software because it is labeled as REMote ON on the back panel of the radio.
I hear what you are saying but I am just explaining what would be clearer. If you want to take it a step further the radio label and software should be remote power switch or rem pwr-sw. Just thought for future.
If I connect the rear panel audio out to my computer line in, will that be fed to the computer line out?
To listen to the Line In audio you have to select "Listen to this device" in the "Listen" tab of the Line In Properties in the Windows Sound dialog, accessed by right-button click on the speaker icon in systray (Notification Area).0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 53 FlexControl
- 859 FLEX Series (Legacy) Radios
- 886 Genius Products
- 450 Power Genius XL Amplifier
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 442 Remote Operation (SmartLink)
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
