BARTG RTTY Contest S02R
Phil M0VSE
I worked most of the BARTG RTTY contest over the weekend using S02R. It worked really well although I struggled to hold a run frequency for long (more to do with the operator and power than the radio though).
N1MM with 2Tone worked well for me, the only weird thing that I found, when DI1 was in focus and I clicked on a cluster spot, it was about 2khz out. DI2 didn't have this problem and both instances were set to have zero offset. Not a major problem as I just made sure that I ran on DI1 and used DI2 for S&P but it was a bit strange. I suspect that there is some setting hidden somewhere that I have missed though!
My 6500 with SSDR 1.6 in RTTY mode is a joy to use. I worked almost the whole 24 hours (with a break between 2am and 6am when things got quiet) and everything worked perfectly with zero problems.
73 Phil
73 Phil
