Log4OM with SmartSDR 1.6 how to track the active TX slice ?
Gary, KE8O
I've been running Log4OM for a few months now. Prior to upgrading the SmartSDR 1.6 Log4OM would track and log the frequency of the slice where I had TX enabled. After upgrading to SSDR 1.6 it only follows the frequency of the Slice A regardless if TX is enabled their or not. I tried disabling Auto Switch TX on the CAT port that Log4OM is using via omni-rig. I even checked for a more recent omni-rig SmartSDR.ini and only found the one that Tim provided back on 12/13/14. I then tried creating a new port using OTRSP vs CAT but that port will not connect to Log4OM. Any suggestions ?
3
- 996 Maestro
