6500 with v1.6 CW keying
Mal G3PDH
I notice that with v1.6 CW keying from CWX or an external program such as N1MM activates the ptt tx even when Breakin is off. This is a nuisance when just wanting to check the keying etc. Whilst Keying from N1MM is perfectly ok keying from Logger 32 Morse function has incorrect spacing and is unusable. Has anyone experienced similar or know of a workaround?
Mal,
What methode are you using to key the radio from L32 morse ? In SSDR CAT i have created a Winkey port and in my L32 CW machine I have confiured to use WInkey ( not WInkey2) and selected the Winkey port that I created in SSDR CAT control panel.. CW sounds fine to my non-CW-expert ear..
AL, K0VM0 -
Al, yes, i have set up a Winkey port and set L32 to use that in the Cw machine. The characters are sent correctly but the space between characters is not correct. It is too long. Keying in the same way from N1MM is perfectly correct.0
- 408 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
