N1MM+ setup audio question
Setting up N1MM to use in QSOP and using the new mic record feature ok.. Only problem is that to play (transmit) the stored audio message, the radio has to have DAX on, and with DAX on, I'm unable to use VOX ? Switching the DAX on and off is kind of a pain.  Is there a way around this? Something I'm not seeing?  Tnx.
  • Ed.G
    Ed.G FlexRadio Employee ✭✭
    edited May 2017
    If configured correctly N1MM will send a CAT command that will enable DAX while it is transmitting the stored audio messages.
    To enable this:
    • N1MM should be configured to use a CAT port for control (you probably already have this done since N1MM is keying the radio).
    • Under Config -> Logger+ Audio Setup -> Playback Tab make sure that the "Internal Radio Codec" checkbox is checked and that DAX Audio TX is selected as the soundcard
    • Uncheck DAX in SmartSDR
    When N1MM keys the radio to send a stored audio message it will also send a command to enable DAX during the transmission and then disable it afterwards. When not sending through N1MM you should be able to use VOX.
  • Rob AB1NJ
    Rob AB1NJ Member
    edited January 2017
    That was simple, thanks Ed.
    73 Rob
  • Ed.G
    edited February 2017
    Great! I'm glad it was.
  • Barry J Cohen
    Barry J Cohen Member
    edited January 2016
    Just curious How to record messages on the fly for example if I want to record a message on F10 used to do CNtrl Shift + function # . Cant seem to Record instant messages. I can record on another machine a .wav file and load it and it works but not on the fly recording which I thought was in the new 1.6.17.156? Any thoughts ? Thanks Barry N2BJ
    You can also respond direct to n2bj@comcast.net
