SmartCAT 1.6.17 Com Port Ghosting
Tom-KJ4QDZ
After installing SSDR 1.6.17, which seemed to go without a hitch, I noticed extra com ports were installed. (Com 105, 106 and 14)
I tried many different ways to rid of them including uninstalling SSDR 1.6.17 as well as VSP. Then I got on this forum and I saw the suggestion from Tim here: https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports and followed the instructions. I then reinstalled SSDR 1.6.17 and found that the extra ports are installed again. Are there any other ideas on how to permanently remove these "Ghost Ports"
I don't think its a show stopper as I am not getting any errors in SmartSDR Cat. I would like to have the ports organized now for digital modes if possible.
What ports do you have defined in CAT? I see the following new pairs
COM5<->COM105
COM6<->COM106
And from the previous installation of CAT
COM4<->COM14
You should see theses port pairs (the lower numbered value) in CAT. If these are valid, there is no need to delete them. If you do, you will break your CAT port configuration0 -
Every port needs two "ends," so this is how it shows up.1
Ahhhhh. Well the pair numbers in the hundreds threw me off as well as not seeing all pairs on the CAT panel. I'm glad this is not an issue. Thank you.
No problem0
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
