PowerSDR2.7.2 Rev O: Waterfall ID, Analog meters, Entire Waterfall shifts with freq, and Panafall on
If anyone running PowerSDR 2.7.2 is interested,
For the 1500, 3000, 5000: I added 2 new larger Analog RX1/TX meters (in addition to the standard EDGE type) to PowerSDR 2.7.2. You can click on the RX1 meter to cycle through the different meters. Added a Full moving Waterfall as you scroll left/right. Added Grayscale option to the waterfall. Added Peak Signal meters for RX1 and RX2, Adjusted S9 signal readings above 30mhz. Adjust Transmit low level for Waterfall and set the Transmit high level to 0db in waterfall. Added The DJ Console code (from dh1tw) to PowerSDR. Added ability to enter HF frequencies in KHz (no need for the decimal point) or traditional MHz
Just added Rev N: Transmit images via waterfall (Images and Text). Similar to Easypal
For the 5000: Now Panafall mode available for RX2 and RX1 together, or Panafall on RX1 with RX2 on Panadapter or Waterfall. Panafall on RX2 currently only activates when RX1 is in Panafall mode. Adjust the RX2 low level (separately from RX1) in the waterfall
Screen shots are on my web site.
I posted it on my web site: ke9ns.com/flexpage.html
Just search for GPL (half way down the page).
You only need to replace the PowerSDR.exe file
Darrin ke9ns
