FreeDV two receivers issues
EA4GLI
Member ✭✭✭
If I open two or more Slices on FreeDV mode all of them start making weird noises. If I close all of them and leave just Slice A, Slice A doesn't recover and the noise remains. I have to completely close the slice and open it again. Sometimes , instead of closing the slice, changing modes "fixes" it. If there are signals, regular USB signals, the slices degrade faster. And if I have 4 or more FDV Slices with S7 or more signals it crashes SmartSDR.
This happens regardless of having the slices on different bands.
Or even if the different slices are in different SCUs.
Also, unrelated, if I TX while on 2m through the XVRT port the waterfall stops in the other panadapters regardless of having FDX on and being on a different band on a different antenna.
I think FreeDV is only supported for one slice with the current release.
David is correct. FreeDV can only be used with a single slice.0
- 683 The Flea Market
