AUTOCQ config
Eder Antoun
Eder Antoun Member
edited November 2016 in FLEX-6000 Signature Series
config autocq audio tx in mic handset
friend good night,MY CALL PY2XAT
I have a FLEX-6300
I'm struggling to put a AUTOCQ recording on software
I can send recording only enabling the DAX key
-enabled DAX, recording perfect passes
but I use a handset of radiosport
I can not output the sound from the mic I have to turn off the DAX key
US WORKING IN RUNNING is impossible I tick on and off the DAX
I need help to send audio recording and mic audio when you press the ESC key to cancel the recording and the TX mic I talk to contest any season
I need help how to enable autocq + mic handset radiosport
  • EA4GLI
    EA4GLI Member ✭✭✭
    Eder, I don't think you can send the front mic audio into the computer. I hope it is a software issue that can be provided in later versions of smartsdr. I record my contest calls plugging the headset mic into the computer directly and then enable DAX in the slice to send the audio when I tx. I posted instructions on how to do it for N1MM in this forum.
    You could use a cable from the speaker output on the back of the 6300 and then connect it to the mic input of your pc, being careful of the volume levels. That should allow you to record your own audio when you enable MON on smartsdr. Not a very elegant or good quality solution but might work for you.
    Good luck.
