IQ stream busy
Mark_WS7M
Mark_WS7M Member ✭✭✭
edited April 2017 in SmartSDR for Windows
Occasionally when attempting to use a program like CWSkimmer I will select a particular DAX IQ stream and the DAX control panel will report "busy" and hovering the mouse over this states that another computer is using the stream.
I'm not sure how that can be because I know no other computer is actively using the streams as I am the only one that could possibly do so.
If I reboot the computer this sometimes goes away but right now my IQ stream 1 is always busy no matter what I do.
Any ideas?
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Mark, check you audio Playback-Recording audio devices, some time afterSW  update , other new  SW installed, Win renumbering audio devices and you DAX IQ can be defined as default  under Win or others, in this case you device for sure will be busy.
