WNB status message clarification
IW7DMH, Enzo
Hello,
I am observing never ending wnb status messages when WNB is off.
In addition, these particular status messages have no handler and I am wondering if it is the correct behaviour.
If so (when wnb is off) what is the information the client should use and what is intended for?
Below there is a dump of a simple telnet client that subscribes itself for all slice and pan message. I highlighted the suspected messages.
73' Enzo
iw7dmh
Trying 192.168.0.14...
Connected to 192.168.0.14.
Escape character is '^]'.
V1.2.0.0
H152A50DA
C1|sub slice all
R1|0|
M10000001|Client connected from IP 192.168.0.200
S152A50DA|radio slices=1 panadapters=1 lineout_gain=92 lineout_mute=0 headphone_gain=33 headphone_mute=0 remote_on_enabled=0 pll_done=0 freq_error_ppb=-1 cal_freq=15.000 tnf_enabled=1 snap_tune_enabled=1 nickname=A201440250079 callsign=IW7DMH binaural_rx=0 full_duplex_enabled=0
S152A50DA|interlock timeout=0 acc_txreq_enable=0 rca_txreq_enable=0 acc_txreq_polarity=0 rca_txreq_polarity=0 tx1_enabled=1 tx1_delay=0 tx2_enabled=1 tx2_delay=0 tx3_enabled=1 tx3_delay=0 acc_tx_enabled=1 acc_tx_delay=0 tx_delay=0
S152A50DA|slice 0 in_use=1 RF_frequency=14.045950 rit_on=0 rit_freq=0 xit_on=0 xit_freq=0 rxant=ANT1 mode=CW wide=0 filter_lo=-150 filter_hi=150 step=10 step_list=1,5,10,50,100,200,400 agc_mode=med agc_threshold=19 agc_off_level=10 pan=0x40000000 txant=ANT1 loopa=0 loopb=0 qsk=1 dax=1 dax_clients=0 lock=0 tx=1 dax_tx=0 active=1 audio_gain=48 audio_pan=50 audio_mute=0 record=0 play=disabled record_time=0.0 anf=0 anf_level=0 nr=0 nr_level=0 nb=0 nb_level=50 wnb=0 wnb_level=57 apf=0 apf_level=7 squelch=1 squelch_level=20 diversity=0 diversity_parent=0 diversity_child=0 diversity_index=1342177293 ant_list=ANT1,ANT2,XVTR mode_list=LSB,USB,AM,CW,DIGL,DIGU,SAM,FM,NFM,DFM,RTTY,FDV,DSTR fm_tone_mode=OFF fm_tone_value=67.0 fm_repeater_offset_freq=0.000000 tx_offset_freq=0.000000 repeater_offset_dir=SIMPLEX fm_tone_burst=0 fm_deviation=5000 dfm_pre_de_emphasis=0 post_demod_low=300 post_demod_high=3300 rtty_mark=2125 rtty_shift=170 digl_offset=2210 digu_offset=1500 post_demod_bypass=0 rfgain=0
S152A50DA|slice 0 audio_gain=48 audio_pan=50 audio_mute=0
S152A50DA|waveform installed_list=FreeDVv0.0.0,ThumbDVv1.0.6
C2|sub pan all
R2|0|
S152A50DA|display pan 0x40000000 wnb=0 wnb_level=57 wnb_updating=0 x_pixels=993 y_pixels=218 center=14.0442 bandwidth=0.008925 min_dbm=-142 max_dbm=-20.516 fps=21 average=78 weighted_average=0 rfgain=0 rxant=ANT1 wide=0 loopa=0 loopb=0 band=20 daxiq=1 daxiq_rate=48000 capacity=16 available=14 waterfall=42000000 min_bw=0.004919999957085 max_bw=7.372800292969 xvtr= pre= ant_list=ANT1,ANT2,XVTR
S152A50DA|display waterfall 0x42000000 x_pixels=993 center=14.0442 bandwidth=0.008925 line_duration=81 rfgain=0 rxant=ANT1 wide=0 loopa=0 loopb=0 band=20 daxiq=0 daxiq_rate=0 capacity=16 available=14 panadapter=40000000 color_gain=24 auto_black=1 black_level=17 gradient_index=0 xvtr=
SADE1F0F2|slice 0 wnb=1 wnb_level=57
SADE1F0F2|display pan 0x40000000 wnb=1 wnb_level=57 wnb_updating=0
S0|display pan 0x40000000 wnb=1 wnb_level=57 wnb_updating=1
S0|display pan 0x40000000 wnb=1 wnb_level=57 wnb_updating=0
SADE1F0F2|slice 0 wnb=0 wnb_level=57
SADE1F0F2|display pan 0x40000000 wnb=0 wnb_level=57 wnb_updating=1
S0|display pan 0x40000000 wnb=0 wnb_level=57 wnb_updating=0
S0|display pan 0x40000000 wnb=0 wnb_level=57 wnb_updating=1
SADE1F0F2|slice 0 RF_frequency=14.045550 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044920 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044930 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044810 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044690 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044670 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044660 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044650 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044760 wide=0 lock=0
SA06B543B|slice 0 RF_frequency=14.044980 wide=0 lock=0
73' Enzo
iw7dmh
V1.2.0.0
H152A50DA
C1|sub slice all
R1|0|
C2|sub pan all
R2|0|
We noticed this yesterday while doing some debugging as well. This definitely should not be happening when WNB isn't enabled. Also, we probably need a way to prevent it from oscillating when the signal levels are low (no antenna). These are issues that we will work through.0
I have noticed that occasionally, under certain band conditions, (15 meters with medium noise, for example), with the WNB set ON and about mid-range, that the WNB indicator cycles on and off repeatedly like it can't decide whether or not it has anything to do.1
That was the very first thing I noticed Ken and with that the noise floor would jump noticeably. That is one of the reasons I was trying to motivate Steve to give a talk on the feature. The video Lee did was good insomuch that it showed wnb working. It did not touch on the jumpiness, the cycling, and what noise characteristics it would address vs those it wasn't designed to address.1
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
