Anti-Vox
Rick Hadley - W0FG
Rick Hadley - W0FG Member ✭✭
edited March 2017 in New Ideas
Searching the community archives, I see this was discussed a couple of year ago, but I've never found an answer.  Are there any plans to add Anti-Vox to SSDR?  Even with the VOX slider backed down to 0, I find it nearly impossible to operate Vox without using headphones and turning the speaker volume far below where it normally runs.
0 votes
Open for Comments · Last Updated
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    RTFM
    18.3.6 How to Configure the Downward Expander (DEXP)
    The Downward Expander reduces the microphone input gain during the quiet periods between spoken words, eliminating extraneous background noise. This improves the apparent signal to noise ratio of your transmitted audio by “soft gating” ambient room noise between words.
    To adjust the DEXP, Enable DEXP and move the DEXP Threshold slider to 0. While transmitting and listening with MON without speaking, adjust the DEXP Threshold until you can no longer hear the background or ambient noise at your operating position. In most cases a DEXP threshold level of 60-70 should be sufficient.
    edited March 2017
    Rick - yes, that feature request is on the list.
