FLEX 6500 - POWER ONLY 20 watts
ALEX
ALEX Member
Flex 6500   radio works well only 1 day. When i am TX QSO I saw an error on LED, then radio to reboot and power became only 20 watts/ all band/ all mode/ ATU also work bad/
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    Check your power supply voltage at the radio.
  • ALEX
    ALEX Member
    edited May 2019
    power is ok)) but 21 watts and 8.35 ampers )) is really?
  • DH2ID
    DH2ID Member ✭✭✭
    edited March 2017
    Alex, check your cables and antenna(s) and then reset your radio, having saved
    your profiles (if you have any) first. Then try again with 10w tuning power and check
    SWR. Also check your power supply for voltage (I use 14 volts for all TRX and RX)
    and your power cables. I had a bad connection for my low voltage cables once,
    which gave off a bit of magic smoke ;-)
    73 Alex - DH2ID
  • dlwarnberg
    dlwarnberg Member ✭✭
    edited November 2015
    21 watts at 8.35 amps sounds like digital mode to me rather then SSB...  take a look at the mode you are in make sure it's USB or LSB not DIGU or DIGL
  • Mike KD2CJJ
    Mike KD2CJJ Member ✭✭
    edited February 2017
    just put it on a dummy load and remove the antenna system from the equation.
    edited March 2017
    Being a hardware related report, I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • ALEX
    ALEX Member
    1 trazistor RD 100 is damage((((((((((((((((((
  • Mike KD2CJJ
    That sucks! Is it in warrantee? Can you remeber what you were doing when it happened? Or just bad luck?
  • ALEX
    ALEX Member
    warrantee yes, but flex in Antarctida and i cant send to US/ I work on delta loop anten whith ATU, flex gave mistake and restart, after only 20 watts/  I did all restart chek cabels, and other/ After  I check tranzistors in driver and amplifier/ driver all good, amplifier - left RD100hf1  - bad/ Soon will change myself/
