F6300 unstable LF carrier?
Steve G1XOW
Steve G1XOW Member ✭✭
Hi, looking for other peoples check/feedback please.
I know I should not expect too much from the F6 series below 1MHz, but I have found two odd unstable carriers (looks like SMPS warble to me). They are both around 800-815kHz (see example pic). Theyimage wobble around a bit and sound like an unstable SMPS.
However, the really odd thing is that the signals is still there, and just as loud with no antenna or coax connected to the flex RF socekts....puzzled, what does yours look like please?
I guess I may have a QRM source, but other than the PC (can't turn off for obvious reasons) nothing else is close enough to generate that high level of signal with no antenna connected.
There is no other carrier/qrm showing from 150kHz to 1MHz with no antenna connected, so these two really stand out.
Thanks, Steve G1XOW
  • Jim  KJ3P
    Jim KJ3P Member ✭✭✭
    edited April 2020
    Same thing with my 6300, precisely as you describe.
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    edited May 2020
    What kind of power supply are you using?  It could be switching noise conducted in on the power cable.  Check with a different supply, preferably a linear one, or even a battery.
  • Steve G1XOW
    edited July 2016
    same on battery power with no switch mode in the shack (ever). steve from Flex has confirmed it as two small SMPS inside the Flex. Thanks.
  • Corey/ KC0YNS
    Corey/ KC0YNS Member
    edited February 2017
    I'm also receiving the same on my Flex 6300 Although I wouldn't have noticed until reading your post...
  • Dave Dave
    Dave Dave Member ✭✭
    edited November 2015
    6300 here.... same but at .799 and .807.1
  • James Whiteway
    Time to calibrate dave dave! Your off too much. :-)
  • Oxford English
    Oxford English Member ✭✭
    edited July 2017
    Not seeing it here
    Tim
  • Dave Dave
    Dave Dave Member ✭✭
    recalibrate my radio and it is exactly .800 but not seeing the one above
    a minute later it has moved to .799.1 ...... its the wobble with no antenna
