Softether.net help
Ken - NM9P
Member ✭✭✭
I have been successful at getting my office laptop (Vista) connected to my home network via Softether.net. I can run SSDR, but it is a slow connection and loses connection often.
But I cannot seem to get a VPN connection using my iPad Air.
It says "The VPN Server didn't respond."
Other times, using different definitions it says "Can't find VPN Node" or something like that.
I have tried L2TP, IPSec, and other types of connection and nothing seems to work.
Anyone have a simple set of parameters that will get me gong? I want to try Stu's new iPad Remote program....
Ken - NM9P
Ken - NM9P
Ken
Softether will not work just by opening up port 5555 for an iPad. You do have to open up a few more port to allow it to work.
Softether supports L2TP from an iPad. I'll have to find the 2 other ports you need to make it play, but I don't have it handy until later today when I can get onto my firewall.
Mike va3mw0 -
Hi Ken
I just checked, and i have UDP 500 and UDP 4500 forwarded to the computer with Softether running.
You'll have to check the Softether documentation for doing an L2TP connection from an iPad. I think you'll find that discussed in this forum somewhere here already.
Mike0 -
Thanks. I will check it out.0
