What is Flex's "Vision" for logging?
Joe - KC2TN
What is Flex's "Vision" for logging while using the Maestro? Seperate laptop? Tablet? Smartphone? Paper/Pencil? or an eloquent integrated simplistic log with basic info that can generate an ADIF?
If using a logger that connects directly to the radio via tcp/ip then you should be able to run that on whatever laptop/computer you are using where the Maestro is being used. If not, you should be able to run smartCat and use a COM port set for direct rig control. If all that fails....crayons still work.
Greg
Logging runs on your PC or laptop just as it does today using SmartSDR CAT. It connects to the radio directly over Ethernet and thus does not go through Maestro. SmartSDR CAT is a client to the radio server.0
- 116 Aurora
- 323 Shack Infrastructure
- 228 Networking
