AL-60B with QSK Board
Bruce Micek
I have just purchased an AL-80B with QSK board mounted. How do I hook this to my Flex 6300?
Would it not just hook up to the amp keying lead on the Radio or am I missing something. What does the manual for the AL60 show as it would be the same for any HF rig?
730 -
A buffer like the Ameritron ARB-704 is recommended but not really needed.
https://community.flexradio.com/flexradio/topics/ameritron-arb-704-flex-6500-and-ameritron-al-80b-am...0 -
RLY:CAUTION!! This jack must always be directly connected to the
transceivers QSK output line. NEVER attempt to operate the
amplifier without this jack properly connected. Do not connect
any devices between this jack and the transceiver.
This jack provides the connection from the Key 2 terminal (D) of
the circuit board. This jack has 5 volts open circuit and supplies
a maximum of 1 mA of current. This jack must be pulled
low (below 2 volts) at least 1 mS before RF is applied to the
amplifier. The jack must not be returned to an open circuit
condition before RF is removed from the amplifier. Failure to
comply with these restrictions will damage the amplifier or the
QSK board.
The QSK board will inhibit the receive signals for one mS after
this jack returns to an open or "high" condition.
DOT NOT use some kind of buffer between the amp and the qsk board. When I was running QSK 5 boards I drove the board with the earliest TX signal I could get out of the rig. You don't want some dumb buffer slowing down the TX signal. The whole point of using this switch is to do QSK. For the flex 6k I would just use the rca plug on the back with no delays in the switching line. The board is sensitive if you try to drive it while still in receive as in you forgot to connect the RCA jack or the amp is in line but rca jack is turned off. The designer, I believe W8JI used a couple of 12v lamps as fuses in the case you are not switched to transmit. The lamps will absorb energy and light up till they **** so you can send CQ and your amp will look like a Christmas tree with the reaction of ****??? Very cleaver idea and the receive diodes are protected. Keep some bulbs on hand I just used some from Radio Shack but I don't remember the current. The current and bulb voltage is in the QSK manual but it's not hyper-critical. If it says 75ma and you have 100ma bulbs good enough
73 W9OY0
- 713 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 128 Aurora
- 992 Genius Products
- 331 Shack Infrastructure
- 235 Networking
