flex 6000 memory channel dstr mode reverts to fdv
GI4FZD
I have been playing around with d-star mode and after saving all the d-star channels it did say DSTR in the appropriate memory box in the memory editor . After a restart, when I open the memory editor i noticed all the DSTR entries had changed to FDV...is there a work-a-round?
Cheers
Paul
GI4FZD
Cheers
Paul
GI4FZD
2
Paul I can confirm this happened to my DSTAR memories as well! I had DSTAR memories saved for each HF band. After a normal power down of my 6300 the mode now shows as FDV ???
I also just noticed all my FDV memories show the mode DSTR now!
Cal/N3CAL0 -
I edited the mode settings back to their correct way and restarted SSDR. It looks like they stayed corrected.
On a side note I also noticed the DSTAR and FDV memories have a RTTY Mark, RTTY Shift, DIGL OFFSET, DIGU Offset values??
Cal/N3CAL
Mine also looked if they had stayed, until I used one, closed memory then went back it had changed again..seems a bit random..something not just right.
Paul gi4fzd0 -
Yes, this needs to be documented as a "Problem".
Cal/N3CAL0 -
I have entered this report into our bug tracker for further investigation. Please report any additional information related to this specific issue in this community topic.
