CW sidetone with LAN remote
Les,
When you use remote audio, CW sidetone is generated in the SmartSDR client itself and NOT the radio. As a consequence, you will only hear sidetone when your headset is plugged into the PC and you send CW using CWX.
The reason is that there is a slight delay created by the Opus codec that is used to encode the audio for remote. It would make using a paddle/keyer plugged into the radio quite difficult because of the delay between paddle closure and when you would hear CW sidetone.
Stu K6TU0 -
Stu,
Thanks for the quick response. So, if I want to use a paddle connected to the 6500, the only ways I can get the side tone would be:
1) using the headphones connected to the 6500, or
2) connecting my powered speakers directly to the 6500.
There is no way to get the side tone out of the powered speakers connected to the PC (unless I want to abandon using the paddle and only use a keyboard to send code). Is that correct?
Les, VE3ABN
That is correct.0 -
Les,
Yes - that is correct. Extract from the SmartSDR 1.5 documentation... (ref page 59)
16.5 OPERATING CW WHEN USING LAN REMOTE When operating in CW mode while LAN Remote is enabled, the CW must be sent with either a key or paddles directly connected to the radio or by using CWX. At present there is no feature to attach a key or paddles to the PC to operate CW remotely.
Note: CW sidetone is only available when using CWX if LAN Remote is enabled
Stu K6TU0 -
Ok. I found a solution ... sort of. I fed the powered speaker output from the 6500 into the line-in of my PC and I set the PC to send this to the powered speakers attached to the PC. The only problem is that there is a delay between the audio out to the headset attached to the 6500 and the audio out to the PC's powered speakers, enough of a delay to create problems keying at 25 wpm. It seems that the PC has a delay in passing the audio.
I guess it's back to the store to buy an audio mixer. That should do the trick.
Les, VE3ABN
Hi Les,
It sounds like a solution will exist when V2.x comes out. You will be able to connect a paddle to your remote PC. And the sidetone will be generated on the PC. Steve discusses the options here:
https://community.flexradio.com/flexradio/topics/remote_is_cw_via_a_paddle_in_scope_for_the_remote_e...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW V 1.5.0.65
SSDR V 1.5.0.145
Win100 -
This is why we do not generate sidetone on the PC for direct connected keying devices when operate in REMOTE mode. With CWX we can generate the sidetone in real time on the PC.0 -
GM All,
I think I have read, but I cannot find it now, that N4PY Pegasus Plus software provides the capability to transmit cw remote using an external k1el keyer and paddle. If this is correct, it would provide another option to consider while waiting for V2.
Tom
This is a practical solution; the K1EL keyer produces the sidetone locally and can be configured to echo the CW CHARACTER that is generated by the paddle actions as an ASCII character on the USB port.
With locally generated sidetone, you don't have the cumulative delays between audio and paddle actions that otherwise make operation very difficult.
Although less elegant (software on both ends and TWO K1EL keyers), the WKRemote program from K1EL does the same thing.
Stu K6TU
Tim...I was about to squawk my lack of sidetone when I found this thread. Of course I'll stand down on submitting the squawk as I now understand the problem. But I suggest someone consider amending the note in section 16.5 as it's grammatically incorrect and cost me some wasted time. As currently worded it says that if I'm using CWX and I want to hear sidetone then I must be running in LAN remote. But it doesn't say that's the ONLY way to hear PC sidetone while in LAN remote. IOW, it doesn't say that I won't hear :PC sidetone when using the iambic keyer.
BTW, this is my second day with the 6500. I'm in hog heaven.
- 692 The Flea Market
- 119 Aurora
