RTTY MODE FLDIGI REV MODE ONLY
iz7auh
Member ✭✭✭
Hi Guys,
I have a problem to decode on RTTY mode with 1.5 release, now on FLDIGI i make a REV mode to decode, if I use MMTTY no need use REV mode why? where is a problem on FLDIGI?
Frank, here is a link to what will solve your problem. The updated .xml files should be available soon from the fldigi author, but I simply edited the .xml files and it works well with no need to reverse the decoding with the LSB association.
73's
W7NGA dan, San Juan Island, Wa.
https://community.flexradio.com/flexradio/topics/fldigi-rigcat-files-need-updated-for-rtty-mode
Hi Frank,
MMTTY, being a dedicated RTTY program, assumes LSB for RTTY, which is traditional and matches the new RTTY mode in SSDR.
FLDIGI, being a general purpose digital mode program, assumes USB for all modes UNLESS you press the Rv button or edit/update the .xml file, as Dan noted above.
In FLDIGI, also be sure to set the RTTY sweet spot to 2210 Hz as mentioned here:
73, Bob, N7ZO0 -
The updated xml files for fldigi work really well here.Tuning is spot on.
Just edit and paste Bob N7ZO's xml code into SmartSDR slice A and B xml file as the xml files on the fldigi download page have not been updated yet.2
- 692 The Flea Market
