Arrow keys and Transmit antennas
Since the up/down arrow keys don't seem to do anything now, how about activating them for up/down frequency change (with option of amount per click). It would make using a laptop remote a bit easier.
Setting up 2 pan adapters (One for HF bands on a dipole and One a 6 meters beam), the receive antennas can be selected and they stay with the pan adapter; however the transmit antenna can not be selected separately for each pan adapter. So switching between the pan adapters requires manually changing the transmit antenna each time you switch from one pan adapter to the other. Both pan adapters change transmit antennas when one of them is changed, It should be able to be setup with the correct transmit and receive antennas and then the system switch when the pan adapter is selected.
Just a suggestion,
Phill Beistel (WB3DHF)
- 111 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
