6500 Running Multiple Bands
Ron K2RAS
I did a presentation on my Flex 6500 to my local ham club and a question came up. Since the Flex selects the initial bandpass filter prior to the ADC, if two panadapters are open on different bands would the selected bandpass filter be 'mismatched', allowing too much noise on the second band? Is this a disadvantage compared to a radio like the Elecraft which can autoselect a roofing filter for each of the two receivers installed?
I presume that the Flex 6700 could have a bandpass filter auto selected for each of the two receivers.
Thanks, Ron
K2RAS
Thanks, Ron
K2RAS
You can select whatever bandpass you wish on each slice?
If you are on a 6500 and widen your Pan or open two pans that are out of a single ham band, the PreSelector disables and you see "WIDE". On a 6700, you can feed each SCU with an antenna and keep their corresponding preselectors enabled if you are within a reasonable border range of a single ham band.
Honestly, in my operating environment, I have never needed a Preselector, which is why it is wise that the 6300 has it omitted as a cost savings. I use a Carolina Windom which is multi-banded and never isolate myself to a single band on my 6700.0 -
Since there's only one SCU in the 6500, when two bands are selected, or if a very wide pan adapter is created, the bandpass filters normally engaged for single-band use are not in-line. This is shown by the "WIDE" indication on the panadapter.
In some situations, this could lead to higher noise levels, depending on your environment, and the characteristics of your antenna system. With a lot of installations, the bandwidth of the antenna tuner in line is a limiting factor.
I don't notice a meaningful performance hit. It's great fun looking at 14 MHz of spectrum and placing slices wherever something interesting appears.0 -
Ron,
The 6500 has one selectable, ham band width filter per band between the antenna and the ADC unless the 6500 is on two or more different bands ( WIDE) then there is no band filter ahead of the ADC. ALL other filtering is provided in the digital domain and filters for each slice are totally independent.
In this technology there is on such thing as a 'roofing' filter in the sense of analog radios.
With the 6700, each ADC (2) has its own set of selectable band filters .
AL, K0VM
Thanks for the quick and knowledgable replies. I guess I will spend some time with the pre-selector on and off and get a personal impression of the impact.
Ron0
- 394 Community Topics
- 670 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 76 Aurora
- 319 FLEX-8000 Signature Series
- 982 Maestro
- 953 Genius Products
- 350 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
