radio control panel location change
N4AB
N4AB ✭✭
edited July 2018 in New Ideas
It would be great to be able to move the individual control panels (TX, CW, EQ, etc.) and lock them in a different location or different screen. However that is not presently possible, but you can move the whole control panel from the right side to the left side of the screen. Position your cursor on the upper bar of the control panel (next to "EQ") and then hold and drag the panel almost to the left side (not all the way), release the mouse button and the panel will attach itself to the left side. Repeat the steps to return the panel to the right side. Its a little touchy because the panel wants to return to the right, but it does work. Who needs this? I don't know. But a left hand person may feel right at home, also with two (or more) monitors, if the radio display is on a monitor to the right side of the operator having the control panel on the left side would make it more visible and centered in front of operator. Most people also look at a display screen from left to right so it becomes the first thing you see. Food for thought.
1 votes
In Review · Last Updated
