FreeDV - The desktop app doesn't show SN bar. It is blue and never moves? FreeDV works fine otherw
Lawrence Gray
Lawrence Gray Member ✭✭
edited January 2020 in SmartSDR for Windows
Installed FreeDV and the FreeDV waveform without issue.  I've had a few QSO's, which were fine.  However, the FDV applet is supposed to show S/N in a green bar.  I see a blue bar, which is not annotated and never moves.  Text is being decoded in the text box.
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited March 2017
    Seems that for now that is all we get.
    Also the waveform version is not ready to bands that use LSB or for the upgraded 1600 version of FreeDV is seems.
    Not certain what the update /upgrade process is , or even who is doing it.
    Steve
    K9ZW
    edited March 2017
    That feature is currently not available in the FreeDV GUI.  We have this on the list to address in the future.
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    edited January 2020
    This is a problem with putting out an experimental Waveform for a mode that is being rapidly developed.  It calls out for active maintenance -- which we really can't expect for now, or can we?
    Has anyone worked with the full FreeDV PC client and the Flex 6000 as opposed to the Waveform?  That would be the way to get the most current version, I expect. It should run like Fldigi or wsjtx, but it would be a pain unless you're set up to run audio through your PC (mic and speakers/phones).
  • Robert -- N5IKD
    Robert -- N5IKD Member ✭✭
    edited September 2015
    The full app works fine through your PC audio and DAX.
