Win-10 Upgrade Notes
k3Tim
Member ✭✭✭
Following is a synoposis of experience of upgrade from Windows-7 to Windows-10 (W10). The download was done in the background but for an unknown reason had to be downloaded a second time. When given the green light to start the process a dialog box indicated it was gathering information and to wait. Ten hours later... The dialog showed same thing. It couldn't be stopped so a reboot was in order. The reboot commenced the W10 upgrade. There is a 15 minute period where nothing seems to be happening except disk activity. The system restarts several times and finally a W10 upgrade screen appears and it indicates the progress.
SSDR had been totally uninstalled per Tim's instructions. I missed removing the (hidden) com ports due to the aforementioned hiccups in the start of the upgrade. A reinsall of SSDR (4.16) went okay except the Dax and Com ports weren't working. (Note: after the W10 upgrade there were no hidden or extranuous com ports so I don't believe they affect the upgrade process). After SSDR was installed and the virtual com ports created, they were flagged as in error by device manager due to registry settings. Running reg cleaner CClean didn't help but did remove some left over junk from the upgrades etc. An uninstall / reg-clean / reinstall of SSDR netted same results. About now I was wishing I'd taken a backup image of the W7 system!
A manual install of the Dax / Cat ports using the files in SSDR driver area did not fix it either (install .INI file). After about five times of trying assorted methods, a manual installation was done using Admin mode (instead of a regular user) and then DaX / Com were installed and working properly. Had SSDR been installed using AdminPriv it is reasonable to assume everything would have worked first time.
Fldigi tested and performs same as before upgrade. This was a seamless changeover.
_..--
k3Tim
"Had SSDR been installed using AdminPriv it is reasonable to assume everything would have worked first time."
It is a function of the installer to elevate user privileges to administrator for the installation of files and running the installers. Most of the time this works, however some network security/firewall/protection software packages interrupts this process. Most Windows errors are permissions related at their core. Next up would be registry issues.0 -
Understood..
How I miss my Imsai 8080 !
I haven't seen anything regarding we Flex'ers and Windows 10 privacy concerns. Everyone should make their own decisions as to what, and how information is to be shared with Microsoft. One thing that is ABSOLUTELY clear with Windows 10 is that much more data has the potential of being shared with Microsoft. The article provides an excellent description of the privacy settings. From this information you will be able to make your own decisions. http://www.slate.com/articles/technology/bitwise/2015/08/windows_10_privacy_problems_here_s_how_bad_...
I just did a win 10 upgrade on a new computer from win 8.1. Since it was a new install of 8.1 I first upgraded my video driver to the Intel driver, then tried the win 10 upgrade. It stalled somewhere in the second reboot and never progressed. I trashed the win 8.1 install and reinstalled a fresh win 8.1. This time I just updated the chipset drivers so every category in the 8.1 device manager was working but no new drivers like the video was added. Totally plain vanilla. I then upgraded to win 10 without a hitch and let the installation register with microsoft. After installation the device drivers from Intel Broadcom and Realtek all updated under win 10 control, automatically.
This is kind of the nuclear option but it did work and win 10 is working great. At some point I may try an install from a fresh win 10.iso to get rid of any old win 8.1 files. Apparently once win 10 registers with Microsoft your computer is known to them but the only way to get there free is through the upgrade.
73 W9OY0 -
Dave,
Thanks for the link - very interesting and useful.
It does look as though, belatedly as usual, MS is going the way of Apple in the way it is trying to hook people in to using a subscription model to distribute a lot of software (I refuse to call them apps!).
I looked at the Technical Preview last year and didn't like it much, mind you it took me 3 years to succumb to Windows 7 and to be fair, apart from a few tiny niggles, I do like 7 but I am running it on a very well specced machine.
Tim0 -
Dave: Thanks for pointing out the link. Went back to the privacy settings and toned them down a bit. Will see how all the programs interact with the restrictions. I like the way Chrome / Google do targeted ads and these follow me around.
TiM0 -
I'm trying to figure out the business model of win 10. Clearly MS does not suffer from largess. I have read that once you upgrade your machine becomes "locked" to a microsoft database so you can reinstall without a serial key. Does that mean you win 8 or win 7 key becomes invalid? Does that mean if microsoft decides to charge on a subscription basis like office 365 you have bought in with your "free" upgrade? I tried to research this but not much is out there. Anybody know the scoop?0
I have no special insight into Microsoft's business model, however from their privacy statement "How we use personal data" you can get a clue. "Microsoft uses the data we collect to provide you the services we offer, which includes using data to improve and personalize your experiences. We also may use the data to communicate with you, for example, informing you about your account, security updates and product information. And we use data to help make the ads we show you more relevant to you. However, we do not use what you say in email, chat, video calls or voice mail, or your documents, photos or other personal files to target ads to you."
The emphasis is mine. Note your browsing history and online queries are NOT exempted and potentially collected by Edge and Cortana! Such data is worth $billions as Google and Apple have proved.
So why not both? Billions for data and billions for subscription0
Lee,
Your Windows 7 or 8 keys will remain valid but only for Windows 7 or 8. When you do the upgrade you are issued a Windows 10 key which I'm not sure you can see. You can revert to your old windows using this info...
http://www.pcadvisor.co.uk/how-to/windows/how-downgrade-windows-10-to-windows-7-8-easy-3615606/
When Windows is upgraded you can later do a full "clean" install. I upgraded a computer running Windows 7 Home Premium 32bit to Windows 10 32 bit. I then downloaded the Windows 10 64 bit ISO and did a clean install to a new SSD on the same computer. All you do is ignore all of the requests for a key until you are finished. I then checked under Update & Security and my shiny new 64 bit installation showed activated. Apparently MS stores info about your computer and when it "sees" it the installation is activated.
You can also use your Windows 7 or 8 key to reinstall those versions at any time.
Jon...kf2e0 -
Hi Jon
I just tried that clean install and I was not able to see activation. Do you sign into a microsoft account when doing the upgrade?0 -
No, when I did the clean install I just clicked to skip the entering of a key until it was done. After the final reboot I checked the activation and it said it was activated. I did read that sometime it can take a bit for the MS servers to verify the activation.
Can you see that activation status and it says it is not activated or can't you find where it tells you the activation status?
Jon...kf2e0 -
Lee,
One other thought... Your computer is on the internet isn't it? It needs to check in with the mothership to activate your installation.
Jon0 -
I did check for activation and I forced a check but it remained inactive yes I am connected when you did the original upgrade did you use a microsoft account?0
I never logged into any account. I started the upgrade from an activated Windows 7 installation and when it finished it was an activated Windows 10(32 bit) account. After that I did a clean install on the same computer to a new SSD. After the clean install the Windows 10 64 bit installation on the SSD shows activated. I still have my original hard drive with the 32 bit installation in the computer and I can boot into either version without issue and they both show activated.
Jon...kf2e0 -
This is virtually what I did except with win 8.1 I started with a active win 10 upgrade on the computer. I used a win10 32/64 iso on a USB 3 and booted from that USB. I nuked the partitions on the SSD using the "advanced" option so I had a pristine SSD then installed skipping every request for a key. It rebooted into win 10 but it was not active I'll wait to see if it activates0
Good luck, the only thing I did different was that I burned the ISO to a DVD and used that for the install. Last resort would be to call the activation folks at MS.
Jon...kf2e0 -
for some reason my product key was blocked
I have decided to stick with Win 8.1. I see no point in risking all this trouble.
The only way I'm going with Win 10 is to buy a new computer with Win 10 already installed. Or maybe buy one with Win 8 and upgrade it before doing anything else.
My 8.1 machine works beautifully so I'm not about to risk being QRT.0 -
I've decided to stick with Windows 7 pro 64bit for the time being. My Windows 10 tests are done on a exchangeable hard disk. The biggest problem I've had yet was that I wanted to install on a 1TB Samsung 850pro SSD. To get Win 10 to install, you have to resize the protected Windows partition from 100 to 350 MB, before installing Windows 10 over a Windows 7. This concerns SSD's only, as the Samsung Migration software resizes the protected partition to 100MB.0
The solution was to put my windows 8.1 product key in the second screen that asked for a key. I also did "new" in the step where I nuked the previous partitions this created 5 partitions 4 little and 1 big I now have a clean install
73 W9OY0
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
