SWR going up when I talk to my Heil
YV5WZ
Shack:
Flex-6300
Elecraft Kat500 ( antenna tuner )
Elecraft KPA500 Amplifier
1st
Symptom ...elecraft amplifier didn't amplified on 20m.....got back to when I changed band....tested with other radio.....everything was good....but with flex no
I unistall SmartSDR....reinstaled.....same
so I decide to run Flex Alone with its ATU
2nd
Symptom I disconnected and connect flex directly to antenna...SWR going up to 2.5 while I talk to my Heil PR40....
Any Idea?
George
YV5WZ
Flex-6300
1st
2nd
Any Idea?
George
YV5WZ
Do you have a dummy load that you can try the same test with ? 730
Just guessing, but it sounds like a problem with your antenna or feed line. If the high SWR issue can't be resolved by the KAT500, then the KPA500 is folding back. It sounds like the Flex/ATU are having the same problem and seeing high SWR as well. Do you have another antenna to try? A dummy load?
I have the same setup that you do here in my shack.
Hey Michael
Sadly, I don't have a Dummy load with me right now.
What would you think is the problem?
Thanks for caring about my question
George
YV5WZ0 -
My guess would be you have a case of RF feeding into your radio. This is generally caused by poor grounding and/or radiation coming back into the shack from your transmission line. What kind of antenna are your using? If it's a dipole sometimes using a BALUN at the feed point will help, if you are using a vertical perhaps you have a poor ground or radial system.
Jim, K6QE
Thanks Steve!
When I perform tune with KAT500....Shows 1.2
KAP500 Show 1.0
but Flex display 1.5 SWR
When I begin to speak....KAT beging to autotune.....It get tune
How ever flex shows 1.5 - 1.6 swr on screen
When I test 6300 alone ( not KAT not KPA )....and after perform autotune with Fkex ATU...swr shows peak with my voice
I haven't note this before......I did just one change ...and it was to add FreeDv Software
Soft reset was done....hard reset was done......
Same
George
YV5WZ
Hello Jim
Thanks for your care about my question
My antenna is a Hustler 6BTV
and it has a RF choke designed by DXengineering
and more than 60 radials
It has been up since 2 years now... I did a check about a month ago
problems begun today....
although....I was concern about RF cause I don't have grounding my shack
Any ideas to fight RF?
George
YV5WZ
I would start with a dummy load. In a pinch, a 100-watt or greater incandescent light bulb will work for you to tune 25 watts or so and see what's going on. Solder a PL239 connector onto it. If you don't have any problem with the dummy load, look toward the antenna.
Jim is right about the RF. Of course, that's also symptomatic of high SWR or a bad ground connection. RF can cause crazy, inconsistent things to happen.
Did you try hitting the manual tune button on the KAT500? I would try tuning in the TUNE mode or using CW to tune the rig. The power is going to fluctuate using SSB.
Thanks again Steve
I will tray to find a dummy load tomorrow, someone borrowed mine....and never see it again
About tune button ..Yes I did....and I got 1.2 SWR...while Flex showed 1.6 SWR
That drove me crazy
Now I'm moving Speakers away from Flex....
Antenna should be change ...probably a Hexbean.....however I´m in love with SteppIr
Thanks again...
George
YV5WZ0 -
Definitely sounds like an RFI problem
Suggest you read may paper on How to build a quiet station
https://db.tt/BqC53jCw
Hello Elmer....Thanks for your care about my problem
I don't understand what happened...I didn't have this problem yesterday
You left a link but...it takes me to Modern Radios SDR-101.... Is that one?
Thanks again
George
YV5WZ
Try this link
https://db.tt/xG8SOiRI
It is quite possible that something moved physically or some connection suddenly had a cold soldered connection that acted as a source of RFI...
Over the years, I have found Heil mikes as a result of low quality production (I suspect because Hams are cheap and want inexpensive things) to be a source of cold soldered joints which can result in RFI getting into the radio...
Can you test to see if you have the same issue when you use a different mike.
If the problem only occurs with your Heil mike then likely you have an issue with the Mike or the mike cable...
Hey Elmer
I read all your paper....wow!....you did excellent job ...
I tried to follow your suggestions ( its sunday )....and some of then are not to easy to buy today (Ferrites)
I checked the mic....and back to flex original mic and its the same...so I guess cable and microphone are all right....I grounded Flex, KAT and KPA to same point...not best I would like....but Its grounded...
and no change
I climbed up to roof to check antenna ..and found some radials were pulled out ( probably DirecTV technician)....I repaired.....no change...
I rebuilt and change all R58 cables --make them really shorter......and no change..
move away Bose Companion II speakers......No change...
By the way Elmer, in your Paper (how to built a quiet station) I saw MFJ-931 artificial ground...does it really works?....I'm not really a MFJ fan, cause I concern about quality of that brand.....do you know the product?
Thank again....Its always good hear about your advises
George
YV5WZ
While MJF quality is not the best, I have used the MFJ-931 from apartments 60M above the ground with great success. I have heard from others who have had similar positive experiences
It sounds like you need to start using some Ferrites..
The rule i use is that you can never have too many ferrites
Howard
KY6LA
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
