ATU Bypass on and off
Check PP 73-75 in the SmartSDR Manual for a complete description of how this works.0
Manual is wrong, well it leads you to think different then software actually does.
If I press ATU it tunes and says success, if I press it again it goes to bypass..... great.... but if I press it again it retunes.
Need a in/out button.
Agreed, I have an ATU (SG-230) on a longwire at the feed point (I never use the flex ATU) and a vertical that I use the ATU in the flex on.0
Pressing the ATU button does not toggle the ATU into bypass mode.
When the ATU is off, it is in bypass mode indicated by the ATU button not being illuminated.
The manual says..
Press the ATU button to initiate an ATU tuning operation. The ATU will set the power output to approximately 2W on 6m and 10W on all other bands during the tuning operation.
The ATU will tune until it either achieves a successful impedance match as shown by the SUCCESS indicator, leaving the ATU button illuminated indicating that the ATU is engaged or that the ATU cannot achieve a successful match, shown by the SUCCESS BYP indicator leaving the ATU button unlit indicating that the ATU is not engaged (in Bypass mode).
Note that if the ATU determines that being in Bypass provides the best match, this is a successful ATU operation.
Pressing the ATU button while in Bypass mode, will initiate a new ATU tuning operation.
Yes that's how it works but it should work differently, ATU should simply put the atu inline and lite the button, If already inline then it should bypass the atu and unlite the button and there should be a button that initiates a ATU tuning.1
I agree. It should be redone, very confusing and awkward. Also when you turn off the ATU button and leave the Mem button on, it says Byp Mem, What does this mean? My understanding is to go into Byp both buttons need to be off, then it just says Byp. A definite change needs to be made!0
I recommend that you review the SmartSDR for Windows Software Users Guide, Section 21 - How to Operate the ATU. It has the answers you are looking for. It shows all of the possible states and what the buttons and indicators show when in those states.
The MEM button enables ATU memories. That is it. Nothing more. It has nothing to do with the state of the ATU. When enabled it will save ATU memories and retrieve them when an ATU tune operation is initiated.
There are two states for the ATU; enabled or bypassed.
When the ATU button is illuminated, it is enabled.
When the ATU button is not illuminated, the ATU is bypassed. The bypass state is reinforced by the green BYP shown in the status indicator.0 -
It all works fine here and not so hard to figure out, A good design I think.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
