global and transmit profiles setup considerations
anyway for u folks that have been thru this, have u found a format that you follow that lets you change these modes, then change freq. - using the transmit and global profile save feature seems to work but I'd appreciate hearing how everyone has approached this matter!
Steve
Hello all I can't get my flex5000a working at all1
I save seprate Global Profiles for things like
SSB Rag Chew
SSB DX
PSK
WSJT-W
and so on, with all the proper settings I want to run with each one.
Such as,
Bandwith TX and RX
DAX
Transmit profile
Mic Input
Mic level
Processor level
EQ Settings
TX jack enable
Then its just a simple pick of the global profile you want to use, changing bands works just fine and it seems to keep all the other settings after doing so.
You can also "nest" a transmit profile inside a global one. I have profiles set up for FLDIGI, WSJT-10, MMSSTV, WSJT-X, and so forth that can be called up inside any Global profile. Reduces the tedium of re-entering data and helps build a good custom set.0
Larry...George...thanks....
George...like u I'm trying to do the same thing...the nested xmt profiles work nicely inside a Global profile. Looks like I'm headed in the right direction.....appreciate the inputs...
Steve
I use FRStack. The MRU is a great scratch pad memory and the other fields make a great custom band/mode switch Plus its easy to export to my remote computers0
When I set up a global profile I am not able to control equalizer on and off. Does anyone know of a workaround?0
Save EQ settings in a transmit profile and that transmit profile can be saved within the global profile.
Thanks Larry, my objective is to have a profile that when in a voice mode on a net (MARS) and I have a MT63 message come through, I can chose a MixW profile and have the correct DAX, DAX on, no PROC, no DEXP, EQ off. with out it changing freq. This works if I set up a transmit profile and associate with a global profile. The only problem is it changes the freq back to the freq where the profile was last saved. Any thoughts?
Whish there was an option to chose what was saved in the profiles.
- 683 The Flea Market
