Ethernet API INFO
kr4k
The Ethernet API WiKi given this example for INFO:
C16|info
R16|0|model="FLEX-6700",chassis_serial="K00000000",mbtrx_pcb="PC-0062",mbtrx_pcbrev="E",mbtrx_bom="B-0064",mbtrx_bomrev="A",mbtrx_serial="B28154-07 LF",mbpa_pcb="",mbpa_rev="",mbpa_bom="",mbpa_bomrev="",mbpa_serial="",name="",callsign="N5AC",gps="Warming Up",scu=2,slice=8,software_ver=0.0.3,mac=00:18:31:78:4F:B4,ip=192.168.30.136, netmask=255.255.255.0,gateway=192.168.30.1,location=""
However when I use the command I get this:
C09|info
R9|0|model="FLEX-6700",chassis_serial="1514-3143-6700-5667",name="KR4K-JC",callsign="KR4K",gps="Not Present",atu_present=1,num_scu=2,num_slice=8,num_tx=1,software_ver=1.4.16.63,mac=90:59:AF:56:6E:5C,ip=192.168.13.62,netmask=255.255.255.0,gateway=192.168.13.1,location="",region="ULCK",screensaver=model,options="None"
Why the big difference?
My radio
C08|version
R8|0|SmartSDR-MB=1.4.16.63#PSoC-MBTRX=1.3.1.0#PSoC-MBPA100=1.1.2.2#FPGA-MB=0.0.23.167
C16|info
C09|info
My radio
C08|version
The example from the API WIKI appears to be from a very early version of SSDR and the radio's firmware version. Also, your setup (network etc.) is different than what the person that posted the example was using at the time the sample was created. There is a lot of good examples here on this forum on using the Ethernet api and it's command structure. james WD5GWY0
The example was from an early version of the code and has since been changed. The mb fields were dropped from info. We added the "screensaver" (what shows on the LCD) and "options" (e.g. GPS, ATU, etc) fields. A few of the others were renamed for clarity (num_slice vs slice). If you need more info about any of these, just let us know. Feel free to help improve the docs on these commands on the wiki.0
- 694 The Flea Market
