MH-31A8J Microphone and no sound on my FLEX-1500
Paul
I was wondering if anybody else has had luck with this mic, or if indeed I am doing something wrong here. Mic is connected. PTT trips transmit, but no modulation, no FWD Power. Have checked Mixer Form, Antenna Form (set to SIMPLE) and tried mic boost. The radio will tune OK, but there is no mic audio.
Thanks!
Thanks!
Having VAC enabled will do that, you may have already eliminated that.
73, Jay - NO5J0 -
Is Mic enabled in mixer?0
I had the same problem with my 1500 when I tried to use the mic off off my yaesu FT897D. I had to get a MH-67A8J off ebay and have never looked back
Thanks everybody! Will try disabling VAC tonight Jay. I do have MIC selected in the mixer Paul.
John, with your new mic did you need to disable VAC?
Paul
No Paul, I can use vac and with it switched off.
A final followup - I have found if I do turn VAC off with this mic it does work. Not a big deal, but I have ordered an MH-67A8J to see if I can eliminate that restriction. Again, thanks to all for your help!
Paul Sampson0
- 688 The Flea Market
- 105 Aurora
