v1.4.16 won't load
K9SO
K9SO Member ✭✭✭
edited March 2017 in FLEX-6000 Signature Series
very briefly you loaded a v1.4.14. I loaded that and everything worked fine. For the first time I actually had a working NR feature.
I loaded v1.4.16 and while it loads fine, during the radio update I get the error message "This SmartSDR version is incompatible with the selected radio's model"
I have a brand new out of the box 6500. Hardware version 1.3.55. Reverts to sw 1.4.3.132 where the NR does not work at all.
    edited March 2017
    I converted your post to a HelpDesk support ticket for expedited resolution
    edited March 2017
    Corrupted firmware is suspected to be the culprit.  Radio recovered via a HelpDesk support session.
