Is App Available for Decoding Arbitrary FSK Signal
Attached is a screen capture signal.
I am in San Diego in case some local want to give it a go.
Thanks for any information.
For a truly arbitrary FSK, or pretty much any HF signal, can recommend:
http://www.wavecom.ch/content/pdf/brochure_w-code.pdf
For strong, local in San Diego, suspect this is a USN transmission, which means it will likely be encrypted and always look like random characters. Not sure if that would be the primary frequency 29.2 MHz or a harmonic.
Gus,
I looked at the information for w-code and it looks very interesting. Have you used w-code with a Flex 6K? How did you interface it to the Flex 6K, IQ stream? Can you provide a ballpark price range for the software?
Thanks,
Chuck - KJ6HT
Have used W-Code with Perseus, not Flex6k. However, IQ interface seems flexible enough.
Have also wanted to try:
http://www.hoka.com/pdf/code300-32_spec.pdf
Think pricing today is in range Hoka $4k and W-Code $8k. Both allow you to decode multiple signals simultaneously.0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
