Want to use CCW SDR4+ as 2nd Recvr with Flex-3000
Top Dawg
Top Dawg Member ✭✭
edited September 2019 in FLEX Series (Legacy) Radios
I have a Cross Country Wireless SDR4+ receiver that I would like to integrate with my
Flex-3000 system. The  SDR4+ can and does use earlier versions of PowerSDR 2.0 which leads me to believe it may also work with the Flex. Can someone point me in the right direction to do this?
73 Robert AA6UP
  • K2CM
    K2CM Member ✭✭
    What do you mean by "integration"? Do you want to put it inside the box? Do you want to display the output on the Flex panadapter? Neither of these two options are possible. As far as making it a second receiver with the Flex, you could certainly do a bit of audio manipulation and put the F3000 on the right channel, and the other unit on the left channel.
