Fun with Lasers and FRS Stacks
K6OZY
Member ✭✭✭
Prepping new add-on pieces for our All Flex 6000 Field day 2015, I decided to mix some CP24's with the wonderful FRS Stacks software written by AA3RK. I setup the 23 hotkeys in FRS Stacks using Alt-Shift-A through Alt-Shift-W, and bound them to the CP24 using the MacroMaster software.
I took my digital caliper and measured the inner diameter of the buttons to be 11.5mm wide by 13mm tall. I then used Adobe Illustrator to create a template. I printed it out on my printer, did a few alignment tests on my laser cutter and cut them out. I did not want to do it by hand because I knew it would be messy!
https://www.youtube.com/watch?v=JZGUSNvl1gA
After it's all cut out, I inserted them into the blank keys and it turned out pretty well!
Thanks to Howard KY6LA for the inspiration to give it a whirl.
https://www.youtube.com/watch?v=JZGUSNvl1gAAfter it's all cut out, I inserted them into the blank keys and it turned out pretty well!
You could be on to something here, a radio with buttons.0
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
