Maestro direct connection clarification
IW7DMH, Enzo
Hello,
in Maestro datasheet I read it can connect directly to FlexRigs.
I am wondering if this capability will be inside Maestro firmware or if this capability will be included in next FlexRig's firmware releases.
73' Enzo
iw7dmh
73' Enzo
iw7dmh
This connectivity is a function of the operating system running on the device to enable a link-local IP address to provide IP communication between the radio and Maestro. It works exactly like a PC running SmartSDR for Windows. No special firmware is required.0
Thank a lot for your answer Tim,
but I am missing something else: if I can connect Maestro directly to my Flex-6300 it will be Maestro's OS to enable a link-local IP address. Which is Maestro OS?
Maestro will use embedded Windows.0
Ok, that was the missing part.
Thank you
73'
- 683 The Flea Market
