Erratic changes of receive ports.
Jim Bryce W5HFS
Jim Bryce W5HFS Member ✭✭
edited November 2018 in SmartSDR for Windows
The receiving antenna port designation on my Flex 6700 running version 1.4.11.60 hops around erratically. It inserts Loop A or Loop B resulting in no signal and sometimes strange noise and "phantom" signals every 10 to 20 KHz. This is especially bad on 20 meters. This only started happening with the latest software version. I'll see ANT 1 with Loop B for receive, something I've never intentionally set. I have to hop around to different antenna settings and eventually release the Loop B (sometimes it is Loop A) and then, mysteriously, I get the ANT 1 I'm seeking. So far I've not been able to establish a consistent pattern.
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    Just an uneducated guess but could your logging program be sending commands to the rig causing this? I was told they changed some commands. Try not running the log for a while and see if it stops.
  • Jim Bryce W5HFS
    I'm not running any logging or CAT or any other programs.
  • Jim Bryce W5HFS
    edited July 2016
    Correction: I am running DM780 to decode digital, but I've been doing that with all other versions of Flex software. In any case, I'll do some checking. Thanks for the idea.
    edited March 2017
    This sounds like band persistence is changing it based on a previous setting.  Can you provide a more detailed of exactly what you are doing when this happens?
