JT65 setup
KC0EM
KC0EM ✭✭
Hi,
I have a new computer and a new 6300 – not that I wanted to get them, but it’s a long story. I am trying to get JT 65 up and running. When I am trying to set up CAT with version 1.4.0 r 5189 of JT 65 I get an error message that reads “WSJT-X Rig failure” and investigating further shows a Hamlib error that reads ”IO error while opening connection to rig.” The computer running Windows 8.1 shows that it recognizes ports 4 and 14 as belonging to the Flex radio. The Flex CAT Port Map shows COM 4 as UNKNOWN and COM 14 as CAT. Going back to the new version of the JT 65 program, I have selected the rig as “Flex 6xxx” the COM port as 4. I selected the CAT button as well.
I suspect whatever I am doing wrong revolves around the JT 65 program. Can anyone offer any help?
“VC” KC0EM
  • David Altekruse
    edited August 2017
    What version of WSJT are you using?  I have the 6300 and am running WSJT-X v1.4.0-rc4 which was suppose to fix a problem with the Flex 6000 CAT option.  I couldn't get CAT control to work either and got the same error you did.  However, I didn't try very hard nor did I try other transceiver models.  WSJT-X does just about everything I need using VOX and no CAT control.
  • DrTeeth
    DrTeeth ✭✭
    edited December 2018
    Set up a dedicated COM port for JT65 - SmartCAT is misleading in that it says one should use a particular COM port (4 in my case).
    You will have to use either the TS 2000 rig or the TS 480 rig. I am using a dev version of 1.5 ATM.
    Above is a config screen of how I got things working. IIRC it is from v1.4.
    Good luck.
  • Larry Loen  WO7R
    edited August 2017
    I did what Guy does.  This prevents conflicts between WSJT-X and other programs (in my case, MixW2).  It works fine.  MixW2 uses CAT for PTT and the two coexist nicely as long as I bring up MixW2 first.
  • George KF2T
    George KF2T ✭✭✭
    edited February 2019
    The Flex 6xxx support is not finished in WSJT-X, so it won't work. It's a HamLib issue, I believe.
    You can (and should) use TS-2000 for your CAT control protocol. Works like a champ. Including PTT.
  • Andrew O'Brien
    Andrew O'Brien ✭✭✭
    edited August 2017
    Or configure your Flex to use Commander and then select Commander in WSJTX
  • KC0EM
    KC0EM ✭✭
    edited November 2016
    That is an option.
  • KC0EM
    KC0EM ✭✭
    That is interesting as the rig I had been using was  a TS 480. I will give it a try. Thanks.
  • KC0EM
    KC0EM ✭✭
    Thank you!
  • KC0EM
    KC0EM ✭✭
    I am glad there is an easy solution. Thanks!
  • KC0EM
    KC0EM ✭✭
    I knew there had to be answers out there.
  • KC0EM
    KC0EM ✭✭
    edited May 2019
    I want to thank everyone for all their help. JT65 is now up and running. 73!
  • KC0EM
    KC0EM ✭✭
    I am using  1.4.3.132.
  • David Altekruse
    edited May 2015
    KC0EM:
    Congratulations on getting JT65 up and running.  I still can't get WSJT-X (v1.4.0-rc4) to pass the CAT Test. I always get Rig Failure.  If you have a chance, could you summarize your WSJT-X settings and specifically what you did in SmartSDR CAT?  (My current settings are Kenwood TS-2000, COM6, 9600 Baud, Eight Data bits, Two Stop bits, No handshake, Mode: None, Split: None.)
    73, David
  • George KF2T
    George KF2T ✭✭✭
    edited December 2016
    David, that version should be updated to either the final 1.4 or 1.5 rc1. Should fix you up right away.
  • KC0EM
    KC0EM ✭✭
    edited May 2019
    David,
  • David Altekruse
    edited May 2015
    Thanks, George.  I updated to 1.5-rc1 per your suggestion.  First I tried FlexRadio 6xxx.  I left CAT Control Network Server blank (which it said I should do for a "sensible default").  That did not pass the CAT Test.  I don't know what else to put in the Network Server field.
    Then I tried the Kenwood TS-2000 Rig but I couldn't get that to work either.  Perhaps I'm not setting up CAT correctly.  I probably should understand CAT better.
  • David Altekruse
    edited May 2015
    Thanks.  I sent mine up exactly like what you have above but still no luck.  I suspect I'm not setting up CAT correctly.
  • Jay Nation
    Jay Nation ✭✭
    edited August 2016
    David
    The FlexRadio 6xxx option in WSJT-X has never worked yet.
    Kenwood TS-2000 should work with with 1.5-rc1 though.
    Can you post a screenshot of this panel?
    It would also be nice to know if your using, or planning to use DDUtil.
    No need to use my settings, I just need to know what your settings are first.
    73 Jay - NO5J
  • David Altekruse
    edited May 2015
    It appears it works now.  Apparently after I set up SmartCat I shut it down.  Very **** of me.   I can now XMIT via PTT and set radio Frequency from WSJT-X.   Does anybody use split operation with WSJT?  Is there any advantage doing that with FlexRadio?
    Thank you for your help!
  • Jay Nation
    Jay Nation ✭✭
    edited August 2016
    David
    No Advantage I've found so far, you can widen your passband out as far as you want/need to for WSJTX so you don't need it. Split is more for rigs that cant change their passband width.
    73 Jay - NO5J
  • Jay Nation
    Jay Nation ✭✭
    edited August 2016
    It's mainly used to keep your TX locked between AF 1500Hz - 2000Hz. to avoid harmonics on your transmit signal. I'm not sure if that's even an issue with SmartSDR.
    73 Jay - NO5J
