Low Power Output? 6300 or 6500
13»
    edited December 2016
    Testing power output on a complex impedance load (antenna) is not an accurate way to measure the power output of the PA.  It needs to be a resistive (dummy) load.  And you have to make sure you are delivering 13.8 VDC at the radio under load to the radio when transmitting to make full power too.
    If you think you have a hardware issue, you should submit a HelpDesk support ticket.
  • Scott N8UMW
    Scott N8UMW Member ✭✭
    edited July 2016
    My load is a bird termaline and is resistive. No big deal. The extra ten to fifteen watts makes a bigger difference with the amp on and in restricted on antenna space so the extra power on the amp might make a little difference, but the radio works fine. Tim, are you saying seven tenths of a volt is going to make a ten to fifteen watt difference?
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    @Scott
    Good point about driving the amp.
    Scott - yes, possibly depending on the frequency.
  • Kevin K
    Kevin K Member
    Just confirming that by removing my MFJ DC distribution box, I am at 100 watts now from 80. Sigh. Scratch another one up to keeping it simple pays off.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    I had the same fix. Flex is wired directly to the p.s. with ring terminals under the binding posts. Other stuff like etc. fed through the distribution box.
