Programming wow!
Gary L. Robinson
Just getting started with programming using the Flexlib and I am impressed so far! Thank you Flex and in particular Eric with his getting started code.
I am a little rusty but after I got the Flexlib DLL's compiled I started a TEST project and set up the event handlers as suggested by Eric and it worked wonderfully. My first TEST project I set up was to change the active slice with a test button so that when I pressed the button on my app the ACTIVE slice would change (only 2 to worry about on the 6300) and at the same time mute the volume on the inactive slice (and un-mute the 'new' active one). So now I can toggle the active slice and mute/un-mute volume with a single button.
It just took a few minutes after I got the handlers all set up to make the little button code.
Wow, after some of the environments I have wrestled with in the past - this one so far is much easier.
This is going to be fun! Thanks again Flex Radio!
---Gary WB8ROL
---Gary WB8ROL
Checkout FRStack. It has this feature and many others. It modifies the mute state of the running slices as you change the active slice in Smart SDR ( or FRStack)
This link that downloads FRStack
https://onedrive.live.com/download?re...
Original FRStack conversation
https://community.flexradio.com/flexr...0
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
