Sudden Frequency Change While Inputting Call Letters into N1MM
mike
mike Member
edited November 2017 in FLEX Series (Legacy) Radios
Have never used N1MM prior to installing N1MM+ to be used with Flex 5000.  In contest mode I was entering a call sign.  I didn't catch the prefix but only the number 5 and 2 letters from the suffix.  So I proceeded to enter what I had so far.  Trying to use the tool without first writing it down on paper.  As soon as I entered the 5 the F5K instantly changed to WWV on 5.000 mhz.  I was aware that entering a numeric would change the freq. but in my mind I was entering a call sign....surprised the heck out of me.  So I prevented it by locking the freq. on the F5K. Lots of DX with a numeric as the first digit.  Seems to get vary busy using the mouse to S&P, adjust the volume, change freq. etc...etc....and now I got to remember to lock freq.
So the question is:  Is there a better way to prevent the change?  Suggestions for a better operating procedure.
Thanks for input
  • Al K0VM
    Al K0VM Member ✭✭✭
    Mike,
       I normally turn off the PowerSDR keyboard short cuts when I run N1MM.  I normally don't use PSDR keyboard shortcuts anyway except for direct frequency entry to the VFO.  Prevents this kind of thing in the heat of battle.
    AL, K0VM
  • Frank PB1SB
    Frank PB1SB Member
    edited April 2015
    Hi Om, i change settings in windows so the focus is on the application where your mouse is. Works great for me. Hope this wiĺl help you. 73 and succes
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    DANGER, DANGER, DANGER
    ALWAYS shut off keyboard input in PowerSDR when you are doing contesting.. For that matter, I suggest turning off Keyboard input permanently so you never run into a problem again.
    Fortunately SmartSDR is smart enough to not have Keyboard Input...
