poor reception on all bands
M Evans
M Evans Member ✭✭
edited November 2017 in FLEX-6000 Signature Series
It seems since upgrading to 1.4.3 I have a permanent attenuator turned on. I have very poor reception on all bands. After I do a reset it seems to work better for awhile but quickly reverts to poor reception. Am I doing something wrong? Any ideas? Is it possible to revert to 1.4 or earlier without really messing something up? I hooked my Anan 10 up to the same antenna and network cable and all seems well! Help
  • km9r.mike
    km9r.mike Member ✭✭
    edited May 2015
    I have found reception via 1.4.3 to be like previous versions of SSDR and that is superior to all other radios. Sorry to hear about you having to settle w/ using another radio. Converting back to 1.4 is easy to do. Just load the software to your computer and select downgrade on the initial SSDR window. It is in the manual.
  • Joe, KQ1Q
    Joe, KQ1Q Member
    edited April 2015
    By "poor reception" do you mean audibly poor, or the signal strength on the S meter and panafall display are weak? If weak signal strength, here are some things to check:
    -  Is your Rx antenna (as indicated on slice receiver) set to the right terminal?
    - Try setting the AGC-T slider (in the Rx panel) to 100%, or just turning it off (reduce slider first)
    - Under ANT, verify RF attenuation is 0
    - If you're using a tuner or amp, as an experiment remove those from the signal chain
    If it still happens, take a screen cap when it's working right, then one when it's weak. Be sure the divider between panadapter and waterfall is set to include a substantial portion of the waterfall display. Post them here and maybe we can figure something out.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Yes it is possible to revert back to 1.4.0  If you still have it on the PC, all you need to do  is run it and it well prompt your to upgrade(downgrade) the firmware. ... But first I would suggest you try a reset to factory defaults and see if your reception is normal.
    AL, K0VM
