How to Key ALS-500M Amp with FlexRdio 6300
Bill Taylor
Bill Taylor Member
edited February 2018 in FLEX-6000 Signature Series
  • Mike va3mw
    Mike va3mw Member ✭✭
    Essentially it is a 1 wire connection.  How far did you get?
    Well, 2 if you count the Coax.  :)
    Connect the Relay out of the amp to the amp keying line on the 6300 with an RCA cable.
    Use a shielded audio type cable with standard male phono (RCA) connectors to connect the RLYjack of the ALS-500M to the transceiver or transmitter normally open amplifier relay terminal.
    This connection has 12 volts open circuit and supplies less than 100 mA of current when pulled to ground.
    Mike va3mw
  • Bill Taylor
    Bill Taylor Member
    edited April 2015
    Mike:
    That is exactly how I connected the 6300 to the AMP.
    6300 Phono connection TX to AMP Phono connection RLY.
    6300 will Not Key the AMP.
    To make sure the Cable is ok, I unpluged the 6300 end and sorted it and that keyed the AMP.
    Just an't figure out the problem???
    Tnx & 73, Bill  K8TBW
  • James T. Whitehead
    James T. Whitehead Member ✭✭
    edited April 2015
    Dear Bill - with the latest software I have to enable the TX port that you are using on the radio each time.
  • John n0snx
    John n0snx Member
    edited April 2015
    Start SSDR..... click on settings.....click on radio setup.....click on transmit.....click on RCA TX1 to enable hit enter on the keyboard and that's it...
  • Bill Taylor
    Bill Taylor Member
    edited April 2015
    Did that and 6300 now keying AMP.
  • John n0snx
    John n0snx Member
    edited April 2015
    GOOD glad it worked for you... Now you can really enjoy radioing with the new Flex
